Capgemini Technology Service India Limited
Last activity: 2 Oct 2025 23:01 EDT
Read-Only Dropdown Shows Code Instead of Description in Constellation Pega
I have a dropdown in Constellation Pega sourced from a data page that contains both a code and a description. The property used for the value is Code, and the property used for the display text is Description.
My dropdown property has a value and is set to read-only. However, on the UI, the code is displayed instead of the description.
For example, Code: IN, Description: India. Instead of seeing India, the UI shows IN.
Interestingly, the dropdown displays correctly when it is editable.
