What is the difference between Specialization and Circumstancing?
Specialization creates separate, named rulesets or class branches for different audiences like organization, division, unit, or work type, so you build distinct rules per context and pick the right one by class inheritance and application stacking. Circumstancing keeps one base rule and adds conditional variants that trigger at runtime when a property equals a value or a date range matches. Use specialization when variants are logically different products or channels and will evolve independently with their own versions and access. Use circumstancing when behavior is mostly the same but needs small conditional changes like “Gold customer,” “EU market,” or “before 12-31-2025.” Specialized rules are selected by class and ruleset precedence, while circumstanced rules are chosen by the best matching circumstance first, then the base rule. Specialization scales for many differences but costs more maintenance up front. Circumstancing is quick for a few targeted tweaks but can get messy if you add dozens. A good rule of thumb: different lineage, specialize; same lineage with conditional branches, circumstance.
Hi @TanyaS58, Circumstancing is for creating different variation of single rule based on property or dates for example loan type is home use rule A and for other use rule B. so this circumstance is applied for a individual rule only.
Specialization is for a broader version where creating different rules for different context for example:region or product. You can specialize for EMEA and APAC region seperately with no correlation for each other . For Example LoanAPP-A or LoanApp-B ,though A and B doesn't have correlation but they can use rules from LoanAPP.
Hope this helps.
HI, Here's a table to summarize the main differences:
| Feature | Rule Circumstancing | Rule Specialization (by Class) |
| Purpose | To handle exceptions and variations in business logic for specific situations.
To create a more specific version of a rule within a class hierarchy, promoting reuse and extensibility.
| Granularity | Applies to a specific rule, creating variants of it. | Applies to the entire set of rules, creating a new version in a different, more specific class. |
| Trigger | Based on the value of one or more properties, or a date.
Based on the class of the object the rule is being applied to. |
| Use Case | A different interest rate for customers in a specific state. | A generic "Approve" process that is implemented differently for "Loan" cases versus "Credit Card" cases. |
Regards, Arek
