Optum Global SOlutions
Posted: Aug 5, 2025
Last activity: Aug 7, 2025
Last activity: 7 Aug 2025 7:54 EDT
Can we share the personalized table view with other operators?
Requirement is to create a personal optimized table view and share that view with other operators so that when they open that particular table they will see that view in the list and they can make it their default view.
@sathish Narsing
Pega doesn't let you directly share a personal table view with others, but there’s a way around it. First, create your custom view using the "Personalize Table" option. Then, a developer or admin can take that configuration and manually add it as a shared view in the section rule or view settings. Once that's done, others will see that view in their dropdown when they open the table, and they can choose to set it as their default. There’s no button to instantly share your view, but with a little help from the dev team, your custom setup can be made available to everyone
