    Citigroup Inc
Last activity: 10 Jul 2025 10:02 EDT
Pega Upgrade to 24.2.2 Stuck .
Below error messages are coming up and upgrade process is stuck /stopped.
NFO LoggingUtilsKt - Apply UDFs: INFO SetupDatabase - ***setting resume checkpoint*** INFO SetupDatabase - ***writing resume property completed.steps.UpgradeDDL=true to file*** INFO LoggingUtilsKt - INFO LoggingUtilsKt - Engine Load: INFO HikariDataSource - HikariPool-1 - Starting... INFO HikariPool - HikariPool-1 - Added connection oracle.jdbc.driver.T4CConnection@7bc6d27a INFO HikariDataSource - HikariPool-1 - Start completed. INFO MainKt - Successfully established connection to database INFO MainKt - Database Type...: Oracle INFO MainKt - Database Version: Oracle Database 19c Enterprise Edition Release Proprietary information hidden.0 - Production Version Proprietary information hidden.0 INFO MainKt - Driver Type.....: Oracle JDBC driver INFO MainKt - Driver Version..: Proprietary information hidden.0 INFO HikariDataSource - HikariPool-1 - Shutdown initiated... Exception in thread "main" java.lang.UnsatisfiedLinkError: /tmp/bc-fips-jnitk5telo60t-libs/libbc-probe.so: /tmp/bc-fips-jnitk5telo60t-libs/libbc-probe.so: failed to map segment from shared object INFO HikariDataSource - HikariPool-1 - Shutdown completed. at java.base/jdk.internal.loader.NativeLibraries.load(Native Method) at java.base/jdk.internal.loader.NativeLibraries$NativeLibraryImpl.open(NativeLibraries.java:331) at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:197) at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:139) at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2418) at java.base/java.lang.Runtime.load0(Runtime.java:852) at java.base/java.lang.System.load(System.java:2025) at org.bouncycastle.crypto.fips.NativeLoader$2.run(Unknown Source) at java.base/java.security.AccessController.doPrivileged(AccessController.java:319) at org.bouncycastle.crypto.fips.NativeLoader.loadDriver(Unknown Source) at org.bouncycastle.crypto.fips.FipsStatus.isReady(Unknown Source) at org.bouncycastle.crypto.CryptoServicesRegistrar.getDefaultMode(Unknown Source) at org.bouncycastle.crypto.CryptoServicesRegistrar.<clinit>(Unknown Source) at org.bouncycastle.jcajce.provider.ProvSecureHash$MD5.configure(Unknown Source) at org.bouncycastle.jcajce.provider.BouncyCastleFipsProvider.<init>(Unknown Source) at org.bouncycastle.jcajce.provider.BouncyCastleFipsProvider.<init>(Unknown Source) at org.bouncycastle.jcajce.provider.BouncyCastleFipsProvider.<init>(Unknown Source) at com.pega.codeloader.UtilsKt.<clinit>(Utils.kt:34) at com.pega.codeloader.engine.EngineCodeDeleter.<init>(EngineCodeDeleter.kt:40) at com.pega.codeloader.MainKt.doAction(Main.kt:64) at com.pega.codeloader.MainKt.invokeCodeLoader(Main.kt:57) at com.pega.deploy.codeloader.CodeLoaderKt.loadCode(CodeLoader.kt:108) at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine$lambda$1$lambda$0(CodeLoader.kt:38) at com.pega.deploy.SetupDatabase.withProgressTimestamp(SetupDatabase.kt:344) at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine$lambda$1(CodeLoader.kt:31) at com.pega.deploy.SetupDatabase.runResumably(SetupDatabase.kt:355) at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine(CodeLoader.kt:30) at com.pega.deploy.UpgradeKt.rulesUpgrade(Upgrade.kt:117) at com.pega.deploy.UpgradeKt.main(Upgrade.kt:46) at com.pega.deploy.UpgradeKt.main(Upgrade.kt) Java Process returned a non 0 value
