Novitates
Last activity: 6 Jun 2025 1:21 EDT
Columns displayed for an object in Insights
Hello All,
I am looking for some additional details related to Available Fields for an Object in Insights. We are using 24.2.2 Constellation.
When i select a particular Data type object in Insights, i initially see few fields shown in the Available fields block and a link saying "more fields". When i click on the more fields i see all the other fields as well. Fine till here..
Now, the question is on what basis these first set of fields are populated on the UI ? Because these are the same set of fields displayed as columns in the popup window, when user clicks on the "View Data" option for the report.
If i want to show fewer or more columns in this popup, i do not see any option to configure them. Moreover, this initial set of fields seems to be different for various data types. I mean i dont see any pattern here.
coming from Primary Fields - No
coming from Hide option for column in report definition - No
Then what else is controlling this list population
I noticed that the JSON response going back to the UI has all the fields returned from the RD. So, there should be something on the UI at runtime which is controlling this.
Attached are the snapshots of two different data types for reference where i see different number of fields on the initial load.
Wanted to know if this columns to be displayed in the "View data" popup to be configurable ?
Appreicate your patience to read through the whole content
Hello All,
@Kamil Janeczek @MeghanAtkins @SidduAdusumalli Need your help here
The link for Insights https://support.pega.com/discussion/ask-expert-reporting-explore-data-and-insights-meghan-atkins-and-siddu-adusumalli? is amazing and gives a very good detail.
Jayachandra
