YuniQ
Last activity: 28 May 2025 12:55 EDT
Handling Large Data Sets with Pagination in Pega
Hi all,
I need to implement pagination to display records from a database table that contains approximately 1 million (10 lakh) entries.
My Requirement:
Display 20 records per page in a UI grid.
When a user clicks on Next page or selects a specific page number, only that set of 20 records should be fetched from the database and loaded into the clipboard.
The expectation is that OFFSET / FETCH (LIMIT) logic should be applied behind the scenes, so that Pega fetches data page-by-page, not the entire dataset at once.
Current Issue:
Even after enabling options like "Allow querying any column" or "Enable pagination", Pega still fetches all the records from the DB into the clipboard.
This causes performance issues and defeats the purpose of pagination.
expecting senario,
I want to limit the records fetched from the DB using pagination (OFFSET / FETCH) and load only 20 records per request — not the full result set.
My question.
What is the correct approach in Pega (Infinity version) to handle this?
Can this be achieved using a Data Page with Report Definition or do I need to use Connect SQL?
How can I pass and use parameters like PageSize and PageNumber in a Report Definition or Connect SQL query?
Hi all,
My Requirement:
Current Issue:
expecting senario,
My question.
Looking for a scalable and performance-friendly solution to handle large volume pagination.
Karthik MG
