How do we create a repeating dynamic layout in pega constellation?
Hi @Satya K,
The Repeating Dynamic Layout is a traditional user interface (UI) component commonly used in earlier frameworks, but it is not supported in Constellation. In Constellation, you can replicate the functionality of repeating elements within the UI by utilizing the "Field Group" option available in the configuration settings for embedded data in a view.
When you choose "Display as" for the embedded data, selecting the "Field Group" option allows you to define a specific view that corresponds to your data object. This setup enables the specified view to be dynamically repeated for each row or page displayed in the application, effectively maintaining a consistent layout while presenting multiple records.
For additional insights and detailed instructions on how to implement this feature, you can consult the following resource:
Configuring a list of records Embedded Data field
This documentation provides comprehensive guidance to help you configure and optimize your UI appropriately.
Raja
