Validating PDF while uploading
How can we validate corrupted PDF file while uploading?
Create a Custom Activity: Create a custom activity in your application ruleset. You can name it something like ValidatePDF
Use PDFBox Library: Utilize the Apache PDFBox library to validate the PDF file. You can add the necessary PDFBox JAR files to your Pega application.
Java Step in Activity: Add a Java step in your custom activity to perform the validation. Here’s an example code snippet using PDFBox:
import org.apache.pdfbox.preflight.parser.PreflightParser;
import org.apache.pdfbox.preflight.parser.ValidationResult;
import org.apache.pdfbox.preflight.PreflightDocument;
import org.apache.pdfbox.preflight.exception.SyntaxValidationException;
public boolean validatePDF(String filePath) {
ValidationResult result = null;
try {
PreflightParser parser = new PreflightParser(new File(filePath));
parser.parse();
PreflightDocument document = parser.getPreflightDocument();
document.validate();
result = document.getResult();
document.close();
} catch (SyntaxValidationException e) {
result = e.getResult();
} catch (Exception e) {
e.printStackTrace();
return result != null && result.isValid();
Call the Custom Activity: Call this custom activity during the file upload process to validate the PDF file. If the file is corrupted, you can handle the error accordingly.
Handle Validation Result: Based on the validation result, you can display an appropriate error message to the user if the PDF file is corrupted.
Step 1: Java
Step 2: Property-Set
IsPDFValid
).Step 3: Error Handling
