Requestor Pooling
Idle requestor and active requestor depends on one another, Ex: 15 request and idle requestor= 3 and Active requestor configured=10.
pega will first re-use active requestor and create 7 new requestor for processing and again all these 10 will move back to idle and then again 5 requestor will be re- used from idle.
As it is recommended in pega that "never set Maximum idle requestors size higher than Maximum active requestors. Requestors remain unused in idle pool if an idle requestor value exceeds active requestor value."
Please explain "Requestors remain unused in idle pool if an idle requestor value exceeds active requestor value." , ??
Regards
Aditi
