![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-09/3901a976-7e45-4387-b3d8-acd548f6fd81.png?itok=TeYAlrZL)
Ford Motor Company
Last activity: 28 Jan 2025 10:13 EST
Links in Academy Courses
Most of the academy courses like System Architect, Senior System Architect and its related courses have links pointing to docs.pega.com URL. But seems like due to recent changes, some of the links are not working in Senior System Architect course. Is someone looking at these broken links? When will it be updated? or any alternates?
Reply
Updated: 28 Jan 2025 9:44 EST
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/da7084b9-a9c3-461b-afcc-b04a6c62dff4.png?itok=kHpAAuH4)
@Mohan Kumar A as already suggested, please use the following processes:
For Pega Documentation 'page not found' issues:
---> use the 'Feedback' icon on the top right of the article page.
For Pega Academy Topics issues:
---> use the Suggest an edit button on the topic page where you are seeing the broken link or issue.
** Addendum **
I have been informed that since I reported it to the Academy team, the equivalent Doc articles for the initial issue were located and the Academy team have updated the broken links.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2025-01/efe3e5dc-0515-40af-a00c-1f4faa6aaa16.png?h=21a0453d&itok=jmlDT35a)
Tata Consultancy Services
Hi @Mohan Kumar A,
Yes, true, due to recent changes in Pega documentation,
Pega knowledge articles, discussion links, Action Tab -> Rule Get Help and Other links not at all working. It is quite difficult to get the right documents.
@MarijeSchillern and @MarissaRogers Any hlep ?
Ashok
@Bhumireddy I am not clear on the examples you have given.
If you find any broken links within the documentation server itself (eg your 'Pega Knowledge articles' reference) , can we please ask that you use the 'Feedback' button on the top right hand side of the articles itself?
Please provide a concrete example of the 'discussion link' comment? . As announced for several months already, there was a change for articles pointing to older Pega versions. We do not retro-actively correct links on old discussions.
End-of-Life Announcement for docs-previous.pega.com Frequently Asked Questions
@Mohan Kumar A can you confirm how you navigated to this v5 version of Guidelines for selecting an application type?
The link to the Constellation documentation Feature changes and limitations in Constellation does indeed appear to be broken, despite pointing to platform-23.
If you scroll to the bottom of the page where it states
This Topic is available in the following Module:
you will notice that if, from that module based on '24.2, the Platform no longer offers the choice of selecting an application type. The main Constellation UI documentation for 23 can be found under the main User experience chapter.
There does not appear to be any document that lists the 'Limitations in Constellation' per se. The UI version comparison article comes closest to the article that is no longer accessible.
@eddie.jm can you confirm if this broken URL was a one-off as this appears to be one of the latest training modules?
Ford Motor Company
@MarijeSchillern - I searched for Senior System Architect course and then selected version as '24.2. From there, I started the course content.
MohanKumar. A
** Addendum **
In this question, @rawap has provided an ECS document link ( Reuse Layer - Implementation and Enterprise ) , which is a very nice article and document. (Reuse Layer - Implementation and Enterprise), the link is not working. Previously It was working fine; after the Pega document upgrade, it is not working.
So many URLs I have bookmarked a book, but many links are not working.
Ashok
Updated: 28 Jan 2025 10:13 EST
@Bhumireddy please try not to append unrelated questions to closed threads.
If you see broken links, just report them, thanks.
And also please note the info about the legacy version documents no longer being maintained (as docs-previous has been retired). You will need to look for them in the Archives, as already mentioned earlier. Or use the Contact us' form.
You can still find references to DCO on Pega Academy. but the actual article root called 'Implementation methodology and dco' was not migrated unless you can find it under Pega Express. You will need to find similar articles to Understanding-class-structure-and-rulesets-generated-application-accelerator
