Eclantiqx
Last activity: 17 Dec 2024 0:04 EST
DX Custom Component
Hello team,
I have built a component called Slider in SDK. While i am running the story book in visual studio i am getting the output as per the requirement and i am able to add in App studio after publishing the component but when i am running it is not displaying in the portal.
Can you guys help me out with this issue?
Mamatha Adiraju
***Edited by Moderator Marije to change type from General to Product, added Product details and Capability tags****
Reply
Are you able to see the new component in Rule-UI-Component?
Eclantiqx
Yes, I am able to see, even I have added it in portal also, but the widget is not visible in the output.
Mamatha Adiraju
Updated: 11 Dec 2024 9:53 EST
Thanks for confirming. Can you please create another field-level component (TextField) and publish it to isolate whether the issue is specific to the slider component or all components?
Please note: Slider is available in OOTB in 24.2 version for Integer Data type.
Rulesstack Private Limited
Hi @Mamatha Adiraju,
- Pega Logs: Check the logs for any errors related to component rendering.
- Browser Network Logs: Inspect the browser's developer tools network tab to ensure that all necessary resources are being requested and successfully loaded. Missing resources could cause the component to fail.
Eclantiqx
Hi @Mohd Qizer Uddin, I have even checked the logs I am getting the error like "Error while processing JWT JSON web token is rejected during signature verification due to bad signature : Expired JWT" Could you please suggest me the solution regarding this issue.
Updated: 11 Dec 2024 1:06 EST
I think Expired JWT error, you need to either refresh the token or issue a new one.
or
Fixing the "Bad Signature" Issue
- Check the JWT Signature: If the signature is being rejected, the problem could be twofold:
- The JWT might have been tampered with.
- The signature verification key (or algorithm) might be incorrect.
- Ensure the correct signing key: Verify that the key used to sign the JWT is the same key being used for signature verification. This is particularly relevant if you’re using a public/private key pair or a shared secret.
Eclantiqx
Updated: 11 Dec 2024 2:10 EST
Refresh the JWT Token
OAuth 2.0 Refresh Token: If the JWT token is issued as part of an OAuth 2.0 flow, you likely have a refresh token that can be used to obtain a new JWT token without requiring the user to re-authenticate.
- Request a new access token using the refresh token: Use the refresh token to request a new access token from your authorization server. The request typically looks like this:
POST /token,
grant_type=refresh_token, refresh_token=YOUR_REFRESH_TOKEN , client_id=YOUR_CLIENT_ID , client_secret=YOUR_CLIENT_SECRET
Hi @Mamatha Adiraju ,
If you find a solution, please close this thread by marking it as the accepted solution.
