vodafone
TR
Last activity: 2 Jan 2025 1:49 EST
Pega with WebLogic and Oracle DB CyberArk support
We are currently using Pega with WebLogic and Oracle DB. We attempted to integrate CyberArk for database password management, following the same procedure we used for other services, but we encountered issues. It seems from the log it is "unable to load classes from the database".
Upon reviewing the platform support guide, I noticed a note stating that CyberArk support is available for environments using IBM WebSphere. Could you please confirm if Pega does not support CyberArk with an environment uses WebLogic and Oracle DB?
WebLogic Server Version: Proprietary information hidden.0
Oracle DB 19c
unable to load classes from the database: weblogic.common.resourcepool.ResourceDeadException: 0:weblogic.common.ResourceException: Could not create pool connection for datasource '<pegarules_datasource_name>'. The DBMS driver exception was: PDKTU006E Timeout has expired (Reason=[Send timed out], Connect=[15:56:57:122] Send=[15:56:57:122] Recieve=[15:58:50:949] Failure=[-1])
