Evonsys Inc
Last activity: 4 Mar 2025 19:58 EST
Unable to download Constellation Modernization Assistant component from Marketplace
Unable to find the Constellation Modernization Assistant component from Marketplace as suggested in the following Pega article. Constellation Modernization Assistant component
Updated: 1 May 2025 8:34 EDT
Constellation Modernization Assistant component is not released for public yet. Once launched you can download the tool from MarketPlace.
Updated: 13 Nov 2024 12:33 EST
Evonsys Inc
@Aditi Mehta Is it released for the partners or clients? If yes, how to request it?
Please reach out to your account team for early access.
Constellation Modernization Assistant tool just got released on Marketplace. You can access it now.
Rabobank
@Aditi Mehta Do you know how to access the tool in Dev Studio home page? I am unable to find the link anywhere. In documentation it says
"On the home page of Dev studio, you should see a button to launch the Constellation Modernization Assistant."
Please help with screenshot if possible.
The modernization tool button will appear below the release banner on home page as below:
In case you are not able to see the button immediately post import of the component, try these steps
- Check if the component is enabled for your application.
- Re save the application rule.
- Try log off and log in back, to reload the Home screen.
Rabobank
@Aditi Mehta
- AppModernization_20231226T163010823 v 01.01.01 has been added as component in target application
- application rule resaved
- Logged off and logged in back - but still unable to view the section above guardrails.
Few points to consider
- Target application is a non-constellation app in Version 24.1.1
- Target application is saved with a password. Can that be a reason?
Anirban
@AnirbanBhattacharyya you have customized the section Data-Portal.pyStudioHome in your application stack - this section is updated in PegaAppModernization:01-01-01 but your override is masking this change - you need to add the dynamic layout with the tool to your override.
Rabobank
@RichardMarsot Thanks Richard. Yes this was indeed the reason. Thanks it is solved now.
Corporaci?n Credomatic SA
CR
@RichardMarsot Thank Richard, I was able to see the banner.
