Srinsoft Technology
Last activity: 29 Oct 2024 2:43 EDT
Property Value not setting in section
Hi Team,
I have created 3 section and using the same property in 3 sections, but if I click on submit and come back, the value is not setting up.
The issue is with only for one section not for all sections.
Note: we are using one section for one time.
Reply
Please add action set changed event for the property to perform Post Value
Srinsoft Technology
@RameshSangili Thanks Ramesh for the response, even if we use post value onchange event it was not working.
What happens to the other properites? Are they storing the values correctly?
Srinsoft Technology
@RameshSangiliLet me explain clearly
I have created 3 sections( A, B and C) and the properties are a and b
I am using the a and b properties in 3 sections, it was storing the value for 2 sections ( B and C) but not for another one A.
there is no deference between the sections, the deference is name of the sections.
Note: We have another properties in sections, those properties are holding the values in clipboard, even a and b properties are also holding the values but it was not holding he values in one section that is section A.
Eclantiqx
SG
Hi @sreenivasK1292, did you check for any post-processing logic that could be altering the data?
Srinsoft Technology
@VarshiniDasojuThere is no logic in post processing
Maantic Inc
Are all the 3 sections embedded in the same section? Did you find anything happening on tracer after you submit?
Maantic Inc
There used to be a Pega bug where the same property being used in more than one section at the same place caused to overwrite each other's value.
Rulesstack Private Limited
Hi @sreenivasK1292,
Kindly verify the refresh condition upon button click. We can debug this by tracing and examining the property value stored in the clipboard.
