IBM
CN
Last activity: 22 Oct 2024 1:23 EDT
The stage failed entry validation
Hi, our case type occasionally reports a broken process with below error:
"The stage failed entry validation: Please correct the errors indicated and try again"
It's pointing to below step :
the step change stage per a property .NextStage
It's strange that when the broken assignment happen, a correct assignment is also there, in next stage specified by .NextStage.
It happens in prod env and we can not reproduce it in test dev
May you have any idea on this problem? Thanks.
