Include a reference from a Data Page/Configuration rule in a paragraph.
As the questions indicates, can i know how to include the value from a Configuration into a paragraph.
Alternatively, how to refer a value on a Data Page in a paragraph.
@Abhijit To include the value from a Configuration into a paragraph you can use the following code snippet to directly reference a system setting in the paragraph rule: html a href
@MarijeSchillern Hello,
The above code works for a system setting to be referred.
However, i am still unable to refer a Configuration (Data page) in the paragraph rule. Is there any way to do it?
