Run in parallel check box for rdb save is a background process or foreground process ?
If this is a another requestor it happens in the backend means other requestor is processing the rdb save and later you should use connect-wait to process it further.
You can also say this as parallel processing because along with current requestor the new requestor is created and used to process the rdb save.
It will spinoff another child requestor to perform RDB-Save operation if you enabled Run in Parallel
Understand that it will create child requestors to complete the transaction but i want to know whether it happens in background or foreground.
