Copy data from a data page is not working
First of all, I am working from a Standard Edition, and there is no sensitive information in this thread.
I am trying to copy data from a data page to a property. I am referring to this section from a Pega article:
"Optional data mapping on the property form – On the Edit Property form, the Optional Data Mapping field appears when you select Copy data from a data page. Use this data transform to copy a subset of the data from the data page to the property. If you do not specify a data transform, the system copies all of the data from the data page to the property."
https://docs-previous.pega.com/application-development/87/data-transforms
I created a data page D_PageToMapPropertyFromDTUn which uses a data transform to get the page AccessGroup (Data-Admin-Operator-AccessGroup) to its Primary property (so it will copy the whole page). I created a property MapPropertyFromDTDeux of type Single Page, set its data access to 'Copy data from a data page,' and set the data page to D_PageToMapPropertyFromDTUn. I created a test case type, then I updated the pySetFieldDefaults data transform of the case type as follows:
Update page .MapPropertyFromDTDeux
Set Param.void = "Param.void"
I assumed that I did not have to map any property since it should be done by the 'Copy data from a data page' option, and there would be no purpose in setting that data access if I had to map the property anyway.
When running the case type, the page D_PageToMapPropertyFromDTUn is properly set identically to the AccessGroup page, but the property MapPropertyFromDTDeux is blank; it only contains the pxObjClass property.
I would like to know why it did not work as I expected. Did I misunderstand the purpose of the 'Copy data from a data page' data access?
@RusselK1 It seems like the configuration should work as expected. Please verify the data page and property configurations, ensure the data transform is correctly updating the property, and check the clipboard and logs for any issues. If the problem persists, consider creating a simple test case or reaching out to Pega support for further assistance.
Data Transforms > Where referenced { .section}
Use case: Loading data into a page list property
Use case: Loading data into a page property
