Virtusa Consulting Services Pvt. Ltd
Posted: Jul 15, 2024
Last activity: Jul 15, 2024
Last activity: 15 Jul 2024 5:33 EDT
How do I fix below OOTB FixCorr Section
Dispite logging in and out multiple times, the issue persists.
I'm unable to figure it out.
Requesting help
Thanks.
@RajeshNalla
This section you can find out using Live UI feature. You can save it your custom ruleset.
The you can change if the error list section and the resolution section as you required. For example, if you want to display some custom error message for fix corr error, you can provide that.
Also, if you want to give some other selection parameters addition to what you have for input, you can use that also.
