cognizant
Last activity: 16 Dec 2024 23:17 EST
Error while adding fields to Data Type in Community Edition
I created a new Data Type but there is no option to add fields. I clicked on view data model and tried to add from there and got below error. But there is a unlocked ruleset available.
I am facing this error in multiple places. I am not able to add new fields from 'views' as well.
"The following errors were caught
Create new record failed: No unlocked Rulesets/Versions found that are valid for this record. Unlock at least one Ruleset/Version that can contain records of this type"
Attached the document with screenshots
Reply
Maantic Inc
Since you're in Dev Studio, goto the Records tab and edit the columns there.
Maantic Inc
Can you create a 99 version and try again?
Maantic Inc
Raise a ticket with Pega Academy
Eclantiqx
Hi @pradeepchandran,
Please ensure that you save it in the unlocked ruleset, as it seems you are currently saving in the locked one.
Regards
Raja
cognizant
Hi @Koti Raja, As I attached screenshot in the document, I have an unlocked version in the ruleset, I created data type in the same ruleset
Updated: 10 Jul 2024 9:43 EDT
Eclantiqx
Yes I have seen the document which you have posted.
I think lock and save the new ruleset and again unlock the new ruleset.
And also make sure your application ruleset in the top of the stack
Hope it works
Regards
Raja
Rulesstack Private Limited
Hi @pradeepchandran ,
I think you have lock all ruleset please unlock at least one ruleset
Mohd Qizer Uddin
Eclantiqx
Please try it by logoff and login still if you get the same error try to create a branch and add datatype in branch,then merge the branch to unlocked ruleset version.
Prasad.
Updated: 11 Jul 2024 10:58 EDT
cognizant
HI @Prasad Reddy Muddam, I created a branch and added data type to branch but while adding fields, I got the same error. Though interestingly fields got added even I got the error
Please create the new rules using the development branch as a best practice. Can you please create a new branch and check if this issue exists? If yes, please create a support ticket.
cognizant
Hi @RameshSangili, I created a branch and added data type to branch but while adding fields, I got the same error. Though, interestingly fields got added even I got the error, raised a support ticket for the same
@pradeepchandran Can you please confirm the version?
cognizant
@RameshSangili I am using Pega Infinity 23 in community edition
NttData
CN
@pradeepchandranI also meet this problem !
Before this problem,i lenrnt to make branches and merge to application,Branch Development need lock all ruleset,I did as it required.
after that,I am sure i unlocked the ruleset,then i create a dataType successfuly,But there is no option to create a filed.I try to create [+] button in [Data model] canvas but failed...
cognizant
@yikaiz17254581 Yes, it is the same issue. This is because of the community edition
Send an email to [email protected] for any trouble you are having with Community Edition.
It seems that your ruleset version may be locked. Please make sure to unlock it and add the required fields.
Mohd Qizer Uddin
