How To: Reduce the External Dependency on JDBC Driver in Openshift Environment
It's evident that Pega Application PODS needs JDBC Driver to connect with Database. This can be supplied through a Driver URI / Customized pega docker image with JDBC Driver URI to support the need.
But Due to the Driver URI setup, A portal where the JDBC driver uploaded is not consistently available and can't customize the docker image due to client side policy issues.
Also, There's no integrated repository available with Provided Openshift Cluster too.
How to avoid the issue on this context?
