Virtusa
Last activity: 26 Jun 2024 10:26 EDT
Add option in the landing page is not working in Pega 8.8
Hello everyone,
The functionality for "Add", "Edit", and "Delete" on the landing page isn't working correctly, even though the corresponding create and edit views have been created for the data object.
Here are the steps followed:
- Created a new landing page using the "List page" template.
- Selected a custom list page.
- Added the required columns.
- Enabled operations for create, edit, and delete.
- Created corresponding Create and Edit views within the data object class.
However, the "Add", "Edit", and "Delete" options on the landing page are not functioning as expected.Any assistance would be greatly appreciated.
Pega version 8.8
Reply
Updated: 26 Jun 2024 10:26 EDT
If this is occurring in Community Edition and you have gone through the FAQs, you can contact [email protected] for assistance.
@SRIDHAR.N - The table source used is a editable data page ? and if yes after adding or deleting what exactly is happening results are not retaining ? Any errors in the Pega rules logs?
Thank you.
Virtusa
@Priyanka Boga Thanks for the response.
Yes, the source is an editable data page. I didn't find any errors in the logs. I have attached a screenshot showing the application/V2 API request and response generated from App Studio.
Can you please ensure the below items?
-> Configure the required properties for Create and Edit views
-> Configure the Data sources tab in the Data type Settings (Data type -> Settings -> Data Sources)
Updated: 17 Jun 2024 14:36 EDT
Virtusa
@RameshSangili Thank you for your reply.
Yes, the necessary properties have been included in both the Create and Edit views.
Additionally, the default data sources on the settings tabs have been configured. I've attached a screenshot for your reference.
@SRIDHAR.N Any errors in the tracer? or console logs in the browser? What happens when you click on Add/Edit buttons?
Updated: 17 Jun 2024 23:10 EDT
Virtusa
@RameshSangili On click of add from app studio, the request is sent to Pega and a response is received(Application/V2 API), but the expected "Create" view isn't appearing after clicking "Add."
I've checked the tracer logs and haven't found any errors. Attached are screenshots from the Console and Network tabs for your reference.
Note: the application is build on Theme - Cosmos and leverages "Use Constellation UI to render landing pages" setting.
Thanks for your details.
I see that all your configurations seem to be correct. It would be greatly appreciated if you could create an INC ticket to engage with our Product SMEs for further review.
Updated: 18 Jun 2024 15:23 EDT
Virtusa
@RameshSangili this is in the personal edition. I'm not sure if we can raise an incident for it. I also tried the same in cloud instances available through coures, but it did not work.
