Cognizant
Last activity: 14 May 2024 3:00 EDT
Is it possible to handle errors in a decision table using a DT?
How to error handling of a decision table using a data transform.
Reply
Updated: 14 May 2024 3:00 EDT
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-03/0616cffa-1530-4cde-abff-fac83e4635bf.jpg?h=658174c2&itok=sY2fYdoO)
Maantic Inc
You can use this function to call the decision table @pxEvaluateDecisionTable(String PrimaryPageName,String RuleName, boolean bAllowMissingProperties). Pass as true/false in the boolean parameter field as per your requirement.
Maantic Inc
Yes it is. But it depends on you requirement and how the data transform is configured.
Maantic Inc
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2025-01/ed367f4c-2f6a-469f-aa42-351a5040c2f6.jpg?h=5df8b6ee&itok=tYc6HMZv)
I'm not certain about your requirements. Let's say you want to display an error message based on certain parameters like error code. In that case, you can use a decision table in your data transform rule. By doing this, you can retrieve the appropriate error message based on the error code mentioned in the decision table.
Cognizant
@RameshSangili no not error code actually suppose in a decision table if you are passing a input property as null then it should throw an error that input property was missing so how to handle this situation in a DT as in activity we have allow missing properties checkbox
