adeptview
Last activity: 20 Mar 2024 9:59 EDT
Server Error
We are using tomcat 9 and Oracle 19C . Once we start the server it runs and after 5 to 10 minutes the sever goes down.
Can anyone help on this?
Please find the below logs.
Caused by: com.pega.fnx.stream.spi.StreamServiceException: Invalid configuration. Undefined stream provider end point.
at com.pega.fnx.stream.spi.impl.kafka.KafkaAdminSettings.getBootstrapServers(KafkaAdminSettings.java:75) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaSettingsProvider.applyCommonProperties(KafkaSettingsProvider.java:77) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaSettingsProvider.getDefaultAdminClientProperties(KafkaSettingsProvider.java:71) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaServerImpl.getAdminClient(KafkaServerImpl.java:63) ~[?:?]
at com.pega.fnx.stream.spi.impl.processor.create.CreateStreamRequestProcessor.getAdminClient(CreateStreamRequestProcessor.java:139) ~[?:?]
at com.pega.fnx.stream.spi.impl.processor.create.CreateStreamRequestProcessor.createStream(CreateStreamRequestProcessor.java:76) ~[?:?]
at com.pega.fnx.stream.spi.impl.processor.create.CreateStreamRequestProcessor.lambda$execute$0(CreateStreamRequestProcessor.java:66) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1768) ~[?:?]
... 3 more
2024-03-20 03:03:46,791 [, Partitions=[0,1,2]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pySASIncrementalIndexer] Preparing retry 11. Next attempt in 2m on data flow [pySASIncrementalIndexer] on stage [InputStage] with affected partitions: [0, 1, 2]
java.util.concurrent.CompletionException: com.pega.fnx.stream.spi.StreamServiceException: Invalid configuration. Undefined stream provider end point.
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:315) ~[?:?]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:320) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1770) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:842) ~[?:?]
... 3 more
2024-03-20 03:03:47,490 [itions=[0,1,2,3,4,5]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pySASBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pySASBatchIndexProcessor] on stage [InputStage] with affected partitions: [0, 1, 2, 3, 4, 5]
... 3 more
2024-03-20 03:03:48,894 [r], Partitions=[2,3]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pzStandardProcessor] Preparing retry 11. Next attempt in 2m on data flow [pzStandardProcessor] on stage [InputStage] with affected partitions: [2, 3]
... 3 more
2024-03-20 03:03:48,894 [sor], Partitions=[4]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pzStandardProcessor] Preparing retry 11. Next attempt in 2m on data flow [pzStandardProcessor] on stage [InputStage] with affected partitions: [4]
... 3 more
2024-03-20 03:03:48,895 [sor], Partitions=[5]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pzStandardProcessor] Preparing retry 11. Next attempt in 2m on data flow [pzStandardProcessor] on stage [InputStage] with affected partitions: [5]
... 3 more
2024-03-20 03:03:48,895 [r], Partitions=[0,1]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pzStandardProcessor] Preparing retry 11. Next attempt in 2m on data flow [pzStandardProcessor] on stage [InputStage] with affected partitions: [0, 1]
... 3 more
2024-03-20 03:03:49,206 [sor], Partitions=[3]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pyBIBatchIndexProcessor] on stage [InputStage] with affected partitions: [3]
... 3 more
2024-03-20 03:03:49,311 [sor], Partitions=[2]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pyBIBatchIndexProcessor] on stage [InputStage] with affected partitions: [2]
... 3 more
2024-03-20 03:03:49,615 [sor], Partitions=[5]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pyBIBatchIndexProcessor] on stage [InputStage] with affected partitions: [5]
... 3 more
2024-03-20 03:03:49,718 [sor], Partitions=[4]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pyBIBatchIndexProcessor] on stage [InputStage] with affected partitions: [4]
... 3 more
2024-03-20 03:03:49,729 [r], Partitions=[0,1]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyBIBatchIndexProcessor] Preparing retry 11. Next attempt in 2m on data flow [pyBIBatchIndexProcessor] on stage [InputStage] with affected partitions: [0, 1]
... 3 more
2024-03-20 03:03:50,382 [itions=[0,1,2,3,4,5]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pzTakeExecMonSnapshot] Preparing retry 11. Next attempt in 2m on data flow [pzTakeExecMonSnapshot] on stage [InputStage] with affected partitions: [0, 1, 2, 3, 4, 5]
... 3 more
2024-03-20 03:03:51,592 [itions=[0,1,2,3,4,5]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyDeleteMessage] Preparing retry 11. Next attempt in 2m on data flow [pyDeleteMessage] on stage [InputStage] with affected partitions: [0, 1, 2, 3, 4, 5]
