persistent logs and transfer to Elastic / Openshift/Kubernetes
At the moment we have the problem that pega-logs are written in the pods. Is there a solution to make them persistent even if the pods are no longer online?
the second problem is that the Pega logs are not transferred to our Elastic/Kibana (outside Pega environment). Is there a configuration to do this.
Is it always necessary to set up our own EFK stack or can you also send the logs to an external Elasric?
or could this be the problem?
[WebAppLifeCycleListener] Log4j Shutdownhook disabled
Current "user.dir" (default directory) is: /
Current pega.logdir is: /usr/local/tomcat/logs/pega-dplymgr-0
Located PegaRULES logging configuration: file:/usr/local/tomcat/webapps/prweb/WEB-INF/classes/prlog4j2.xml
WARNING: sun.reflect.Reflection.getCallerClass is not supported. This will impact performance.
2024-03-11 15:00:04,584 main ERROR Unable to locate appender "JSONAppender" for logger config "root"
Unable to locate PegaRULES old logging configuration after trying:
<properties>
1001990000-prlogging.xml
pega-dplymgr-0-prlogging.xml
prlogging.xml
