Capgemini
BR
Last activity: 13 Mar 2024 18:05 EDT
Using Oauth 2.0 with Conect SOAP
We recently upgraded our Pega version to the latest patch of 8.6.6 and it was indicated that for this version,
it would be possible to use the OAuth 2.0 authentication model for SOAP connectors as per the official documentation:
Note: Pega Platform supports OAuth 2.0 authentication for SOAP connections in the following product versions:
8.6.3 and later
8.7.1 and later
We started configuring our connector based on this premise and identified that, at the time of processing the connector call,
it triggers the Authentication profile rule to capture the token, however:
8.6.3 and later
8.7.1 and later
It assembles the token – Bearer [token]
Bearer eyJlbmMiOiJBMTI4Q0JDLUhTMjU2IiwiYWxnIjoiUlNBMV81IiwiY3R5IjoiSldUIn0.Z39UdD5V1_oRj1zdMG7aFifB_q7vC8R1d_7T90na_LX6AlPSOJ_L_gOi3OgrqZI2lzcPU751Wlh1QO3v3lbzxUlVLK-es8I7wEp-k2KUixyhVs-dwEbK2PMOe7hZ__Q7JtZestKKKZhy17RdkEw_w9bI2TJMIeacxzvL5fFWWVLu2WaqmBBDD3bxJoFKvIr8bpUWJmBmwTF1spERgJc9dOY24Ib50sVOvsbJAvfy-3J5CYnGZ5vzCOa4E4R8lV57MNmtsKBv6395cY1PFmjli67o2XPRRLQIgjho5aywm4SlE6gtW32jS5MX3gbdN9QTfwirvvOlZmvv8skhoh0Ncw.RmShNeQ_aszz3nXOUxdJ8g.kc3ayaiGKb2Y3JpSmdPnCh74Im8CZsbrGZFuBgZToc5E_9ChL0KMe0SGcL8HjJCcUSqOqJmeStZOpxr7H-9wXUy-I6zHMUsYrirab9xcFiu9b1I8Bu6iua8B1I6Mrt6NcJZdfciN1oywPK_FVc6SB8OXaMqE_ZYGQ9uCBdMopausrmWJTO7JIi8aJTjMf7jqOSXEy7-AkjWfEb7g-2Wc69GkG-EoNuyPsToAWx0OR8bigtmmil1UyE26bpBijsB_QzOK_nMCCOiZ-AHgy61SJrnVJVzgi8zMB0qw3HFW1BR_rnsDW0-YgUN5tR5hOjhBx4cB11X4tMaNqAjfPtcSoWqTcd3cpGC7NsKO90CHwi4XxI5-RPFElkF9cutT-5fqZlhKwkjZm-SPAoDppjgpg91kXZFEbn0aZ7rCQNMrFY7boFEPF0wF_zACQApr6xstnU2Gh442CBasyOPNMsCYYbeY_Nqdm0rNIR4q163J2fnCpHC4MTSDHScwKH4ofeTbMS88nvfF_RAP40yifq3xCtVYfBk_oacQf59wYRluAHE1q7-KT740NNFJm9Rqn5gCOFW8-5XAy4UWHOa7KVsU9XBjPftxVogkkEgpBZK82SiVdr-O62jCY5FxH6U_UhHDLvW69X8EAzd5q4iZ6VZU26uW-kF5qUz1lJSiVpkiPlnjSP2egWzaDNZeaO51AwsPDvkcWXYiNAEwkxvlHwbZnvTztpRolG3N_fB-SrwA0llOjPJPY3OJJxO8g-JY0y4XXonZd1lWndZIZoi0C3H97IB3yg_aut5iuD80Of6CYcVvGa_LSn7hFSGJdkUGAzxdfUxnHt16EcIDpQ1Gp0mewo4jYULVWKjSIUY-yx71V5Vgg0hY9H7X2Eu-e46MbxQjIWqwwrzpX25xp6789NVNPAw8DX9pbJTWgulgU6xS6hFjOESBkNJwTjyFg9NFhOcCOHCdV5QZBryLg_GDQlBEvVWezYJRkdxjrRrXG_nJQyyqGDWbA2cYJxGdy391iVooLEw888DwQccyjZ6LAsBIUB7M2c8gOboeQIWRgnHvkjIn3Hgz2pNoiCtw7gYa-eoDemrk9F7cMdkFX_EJSOlO_Cr4XsvejAB918ahBcOxN2i3ySs9fdVSrv7VTLnY6NVfK75TvaJSEiDvKbLkkbPBz12GdlVoXj1sgGiHuU59tTuJlAxHmxKtQRcMbQ_x65nL_MPw0hQKzWZzNWgN5TONCpKGH0L3zGSbEgoUQ--hP5p3yO5dqvY5jPv8zarMwUC0WbosI-0CW-1R-pboyP7mWD_UoDzL-KP7imGkgRonliLhlepVj4D1PiGUJggH9RO4HJFe0XcMj_DqHGtcxeE82RdfNlDWbk8Be0vN3TbygTaj7yBson4TFsijL9CZP5N10Erg6HLoElfSmyvmN_KcnkpIDsOUHry0i4CkOY6_Wo3NTVGr9afOTRWoFTDqp5M39zp24GUMjGs2xxDU0aBadHbZ3yakw-m5anJTuGCcKLRRwdgwhSWJ850dZPDU5e-nkVsIEAstye4HYEgqOnO4PYGr595Jqy9yb_JBDP0XM_KbK6qVmBsX6wxUk53Rye1dnmsmU9dHBpmjoJO08LNy7zHiQ6uhHctDtqMyrhFqIPAU3MJnQ5pzfCPYBxt0AIwAVmyRz51sVKGc0nDhZzDwhGg-HCevC2kyiaPGi4bWbLa25X4yj5nwimdfCzZE_FWMMfbg_44fEvDKyPVh2pUhcKxJGxWhfgSUFjFvhSR0qE_DzZgKea7Ugf4Y2avdrTvD.wkfai6NUzYzMefUtunI3PA
This means that it triggered our security service which is responsible for this. However, when it proceeds to process the connector call to obtain the response,
it receives the following information:
Exception - java.lang.IllegalArgumentException: Username may not be null
I need support to understand if the authentication part for using SOAP connector – utilizing OAuth 2.0 – is valid for version 8.6.6.
If there is any hotfix to correct this issue, I require guidance.
In Attachment more details
