accenture
PH
Last activity: 13 Feb 2024 6:59 EST
Production Environment Cloud Data Storage Utilization reached 75%
To share some context, the Prod environment data storage utilization has reached 75%. We're seeking solutions to either reduce or effectively manage our PEGA data storage usage. After exploring options and using Pega Diagnostic Center to analyze application behavior, We've narrowed down the research to three potential approaches, but we need more information on these. Here are the details we're seeking:
1. Cleaning-up records on pc_data_workattach table:
a. In PDC, under System Resources > Database > Tables > Schema, we noticed a large byte total on the pc_data_workattach table. Our knowledge is that this table stores case attachments. Can we remove case attachments older than a certain period from this table?
b. Is there any PEGA built-in process/policy that allows us to delete some records?
2. Deleting unused table indexes:
a. In PDC, under Database > Tables > Schema > Index Used Info, we've identified table indexes unused for at least 20 days. If delete these, what are the implications? Is it possible to quickly re-add/restore them if needed?
3. Implementing a Case Archival Policy:
a. Does transferring case data from Cloud Data Storage to Pega Cloud File Storage incur a cost? What is the approximate cost of using PEGA Cloud File Storage?
Besides the mentioned approaches, are there other methods to reduce or effectively manage cloud data storage?
Any insights on these matters would be greatly appreciated.
Thank you.
