Tesar
ID
Last activity: 6 Feb 2024 11:53 EST
Based on ticket on SR-B42374 · Issue 299138
Based on ticket on SR-B42374 · Issue 299138, we experience issue on data import wizard in pega. when we try to import parameter, pega show Unable to perform {1} : assignment does not exists.
i traced the problem, and i found a rule with ID (pzDataImport), i tried to private edit this rule and i turned OFF Draft Mode, the import Wizard works fine, if the Draft Mode is ON, the problem appear as pictured in the first screenshot.
the Draft Mode is on by default. can you provide hotfix product based on SR-B42374? because we cannot find HF Product to install in our server
