IBM
CN
Last activity: 18 Jan 2024 22:00 EST
any page like "Top" to access the parent page of current page
My scenario:
A section -> a Table attached to a page list List1 -> in each row of the Table there's an embedded section (Section1) in which a repeating layout attached to a page list List1(n).Sublist.
There's a section (SubSection1) attached the repeating layout.
So, the UI is: in each row of the Table, we can see SubSection1 appear one or more times.
Now, the question is, in section SubSection1, a button action need run a data transform using its parent page as context, that is, List1(n), instead of the default context List1(n).Sublist(m).
How could I specify "parent" page for running this data transform in action set?
I know Top is refer to top page, but I need refer to the parent page here.
Our current solution is to put the DT inside a Refresh section action though actually I do not need refresh any section. In the Refresh action, I specify "Other section": Section1 and run the DT.
This solution works however it need an extra refresh.
So wonder any better solution to refer to parent page?
Thanks.
