LTIMindtree
LTIMindtree
SA
LTIMindtree
Posted: Jan 4, 2024
Last activity: May 16, 2025
Last activity: 16 May 2025 8:26 EDT
How to integrate Splunk with Pega in Openshift Environment
We'd like to Integrate Pega with Splunk in Openshift Environment. Need help on steps / instructions to for Integration.
***Edited by Moderator Rupashree to add Capability tags***
@Kishore Sanagapalli
Identified High level Overview Steps:
High-Level Overview of Splunk Integration with Pega:
Integrating Splunk with Pega involves configuring log forwarding from Pega to Splunk, allowing you to monitor and analyse Pega application logs in the Splunk platform. Here's a general guide on how you can achieve this integration:
Understand Pega Logging:
Ensure that Pega is configured to generate logs in a format compatible with Splunk. Pega logs typically contain information about system events, errors, and application-specific data.
Set Up Splunk:
Install and configure Splunk on a server.
Make sure Splunk can receive logs from external sources. You may need to configure inputs to listen for incoming logs.
Configure Pega Logging:
In Pega, configure logging settings to generate logs in a format compatible with Splunk.
You can adjust the logging settings in the Pega Admin Studio or by modifying the logging configuration files.
Forward Pega Logs to Splunk:
Use a log forwarding mechanism to send Pega logs to Splunk. Common methods include:
Syslog:
Configure Pega to send logs to a syslog server, and then configure Splunk to monitor the syslog server.
HTTP Event Collector (HEC):
Set Up Splunk:
Syslog:
Configure Pega to send logs to Splunk using the HEC endpoint. Set up an HEC token in Splunk and use it in Pega's log configuration.
Verify Integration:
Test the integration to ensure that Pega logs are successfully forwarded to Splunk.
Check Splunk to confirm that the logs are being ingested and indexed properly.
Create Dashboards and Alerts in Splunk:
Leverage Splunk's search and reporting capabilities to create dashboards and alerts based on the Pega logs. Design custom searches, visualizations, and alerts to monitor specific events or trends in your Pega application.
Implement Security Considerations:
Ensure that the log forwarding process is secure, especially if you are sending sensitive information. Use secure protocols and encryption where applicable.
Documentation and Monitoring:
Document the integration details and configurations for future reference.
Set up monitoring in both Pega and Splunk to detect any issues with log forwarding.
Note: Setup is going to be implemented in our environment from my end. Will share the complete solution upon implementation.
