Accenture
Last activity: 9 Apr 2024 2:37 EDT
HTML To PDF conversion takes long time when a custom section used
Hello All - We have a functionality to generate a PDF document and attach to the case. We use the OOTB rule pxCreatePDF in the process. The PDF generation was implemented for multiple screens with custom section rules. One of the section was configured to show the list of case attachments (which uses a Data Page to display the file names). The PDF generation is not happening on time when the screen with the attachments list is displayed where as the pdf generation for other screens works good.
On analysis, we could see PEGA using an open API to convert the stream to pdf in HTMLToPDF activity which takes longer duration than expected for PDF generation.
This happens sporadic in production. Not replicable in Dev or in Testing environments.
Have anyone faced this issue, if yes, could you please share how to solve this.
Log content:
Log content:
at com.pega.pegarules.integration.engine.internal.util.PDFUtilsImpl.invokePD4ML(PDFUtilsImpl.java:240) at com.pega.pegarules.integration.engine.internal.util.PDFUtilsImpl.generatePDF(PDFUtilsImpl.java:171) at com.pega.pegarules.integration.engine.internal.util.PDFUtilsImpl.generatePDF(PDFUtilsImpl.java:193) at com.pegarules.generated.activity.ra_action_htmltopdf_6f21429218308b1870939b586f71bf9d.step9_circum0(ra_action_htmltopdf_6f21429218308b1870939b586f71bf9d.java:736) at com.pegarules.generated.activity.ra_action_htmltopdf_6f21429218308b1870939b586f71bf9d.perform(ra_action_htmltopdf_6f21429218308b1870939b586f71bf9d.java:213) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2855) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:11470) at com.pegarules.generated.activity.ra_action_pyattachaspdf_a7743fd2c51eca1a1cbb3e940ddc5d93.step6_circum0(ra_action_pyattachaspdf_a7743fd2c51eca1a1cbb3e940ddc5d93.java:524) at com.pegarules.generated.activity.ra_action_pyattachaspdf_a7743fd2c51eca1a1cbb3e940ddc5d93.perform(ra_action_pyattachaspdf_a7743fd2c51eca1a1cbb3e940ddc5d93.java:162)
***Edited by Moderator Rupashree to add Capability tags***
