Estes Express Lines
Last activity: 5 Jan 2024 14:09 EST
Ruleset Drops on Scheduled Automations
Having an issue where our scheduled automations aren't starting because the ruleset drops when the job starts. The workgroup will switch to the scheduled setting; however, the ruleset drops and the job fails. I've noticed the operator id has a new save point at that time, so it's updating the profile when this happens. Is this a known issue - what can I do to prevent it? Thanks
Hello @MichaelM4236,
I think the issue might be related to the configuration for the robot registration. The robot operator record is created automatically by the registration process using the operator record defined as registration in the configuration as profile. In your case, that operator looks like was updated manually by the administrator after the registration process.
The best course of action would be for you to open a support ticket and post the ID here for GCS and ourselves to engage directly with you on a session where we can check your configuration and observe the behaviour.
