Save database query to logs generated by OBJ-SAVE.
Hi ,
Could you please help me how to save SQL query to logs generated by OBJ-SAVE method in activity.
Thanks in advance.
Hi ,
Thanks in advance.
@GopiK787 To log the SQL query generated by the OBJ-SAVE method in an activity, you can enable debug logging on the class 'com.pega.pegarules.data.internal.access.DatabaseImpl'. This will log all the SQL queries that are executed, including those generated by the OBJ-SAVE method. Please remember to disable the logging once you have the information you need, as excessive logging can impact system performance.
