Capgemini
BR
Last activity: 18 Dec 2023 20:16 EST
Pulse - Error to Post - pc_work_social primary key violation
We identified a problem in our flow, where, in the last few days, it has not been possible to create or finalize our cases, as we are identifying an error in using the pulse ootb shape.
In our process, which in the attached document, I include evidence of how it is configured, when entering the case, it calls pulse through the ootb shape, to be able to post a message from the requester
The big point is that when he tries to create the message in pulse, we are receiving the following message:
ORA-00001: exclusive constraint (PC_WORK_SOCIAL_PK) - Violated
From what we assessed, when we use the ootb shape to generate a message on the pulse, it triggers an OOTB Internal and final pzPostSocial activity
and that generates a pyID case identifier to be able to handle each message, to be able to associate it with the case that is making the case post. (Class PegaSocial-Message)
What actions should we take to avoid this type of problem? Are there any internal control rules that we should re-evaluate?
