Bits in Glass
Bits in Glass
Bits in Glass
Posted: Dec 12, 2023
Last activity: Sep 9, 2025
Last activity: 9 Sep 2025 7:07 EDT
How to use repeating dyamic layout in Constellation?
***Edited by Moderator Rupashree to add Capability tags***
@TwinkleChawla
Repeating Dynamic Layout is a traditional UI component, and as such is not available in constellation. However, the equivalent feature in constellation where a piece of the UI (View in constellation) is repeated for each row / page is configured by using the "Field Group" option when setting the "Display as" setting for embedded data in a view. This allows you to select a view defined on your data object as the repeating UI.
There is some more information in the below linked documentation.
Configuring a list of records Embedded Data field (pega.com)
