Sun Life Financial
PH
Last activity: 6 Oct 2023 9:40 EDT
PDF Connector Compatible PDF versions
Good day.
We have an automation that will have to process PDF. We used PDF connector to open and split the pages of the PDF. However, we are encountering this error message "Object reference not set to an instance of an object".
Upon checking, the PDF version of the file is PDF Version : 1.4 (Acrobat 5.x). Is there a limitation on the PDF versions the PDF connector can open? We are using Pega Robotics Studio version 19.1.92. We are able to open PDF versions 1.5 and 1.7.
Thank you.
May
