AMERICAN EXPRESS
Last activity: 10 Oct 2023 9:34 EDT
Oracle DB Active-Active DB Cluster configuration support for PEGA 8 / Infinity
Currently we are running our application in PEGA 7.4 and planning to uplift to PEGA 8.8 end of 2023. Also our current DB setup is Active-Passive. We are looking for options to improve the application availability as there might be scheduled outage on server patching or PEGA version upgrade or any other. Does Pega 8.8 supports Active-Active DB setup ? If so any guidance / support instruction and what is the criteria of the work type to accomodate Active Active.
Note: out application cases are 90% straight through to resolution, but some of them worked on by users manually by workflows and cases are persisted in the DB.
