Default DataSet(Kafka)
Which dataset does pega use by default for stream(Asynchronous) processing? Let's say we want to setup a separate kafka cluster and leverage the same for stream processing(queue-for-processing method). For this scenario, which dataset will pega use behind the scenes for managing the processing of these queued records?
***Edited by Moderator Rupashree to add Capability tags***
