Integrate Pega with Azure DevOps for CI CD
Can anyone help with the clear step wise documentation to integrate Azure DevOps with Pega and leverage the Continuous Integration - Continuous Delivery
***Edited by Moderator Rupashree to add Capability tags***
@GouthamiB @GujjulaSiva
Pega Platform supports DevOps practices such as continuous integration and continuous delivery to quickly move application changes from development through testing to deployment. While Pega Platform has built-in DevOps capabilities, it also supports integration with third-party tools. However, as of the current version, Pega has out-of-the-box support for JIRA as a project management tool. For Azure DevOps integration, you would need to use REST APIs or similar methods to connect the two systems. Unfortunately, there isn't a step-by-step guide available in the provided context for Azure DevOps integration with Pega.
Automating deployment pipelines using Open DevOps solutions
Planning your Pega Customer Decision Hub environments > Pega DevOps
Understanding the DevOps release pipeline
Devops with VSTS
Devops with VSTS
PEGA Integration with Azure Boards
