Report definition fail to retrieve value for some properties from case
In a report from a Report definition running, in which each line represent a case, found some properties from some cases are empty while some others are normal (non-empty)
As check in clipboard (pyWorkPage), in those problem cases, found the properties have normal (non-empty), wonder why they can not be shown in report.
may I know whether any possible reason?
the tricky part is that, some cases are normal.
Thanks.
