Infosys
Last activity: 22 May 2025 15:39 EDT
When I try to retrieve the property, it is resulting in no value as output in report Definition
When I try to retrieve a value through a query runner, I am getting results, but when I try to retrieve the same property, it is resulting in no value as output in report Definition.
To verify that same property, I have added filters and added a condition with not null. I am receiving records, but the same property, when I added it in the query, is showing no values.
How to fix the issue?
Reply
Updated: 26 Dec 2024 2:45 EST
Can you please share the query you ran in the Query runner ?
Also please fetch the DB query using the tracer while running the RD and compare it with the query ran using runner?
Infosys
@bathv
SQL Query:
SELECT pyUserIdentifier, pyUserName, ProducerGLNString
FROM pegadata.pr_operators
WHERE ProducerGLNString IS NOT Null;
DB query:
SELECT "PC0"."pyuseridentifier" AS "pyUserIdentifier" ,
"PC0"."pyusername" AS "pyUserName" ,
"PC0"."producerglnstring" AS "ProducerGLNString" ,
"PC0"."pzinskey" AS "pzInsKey"
FROM pegadata.pr_operators "PC0"
WHERE ( "PC0"."producerglnstring" IS NOT NULL ) AND "PC0"."pxobjclass" = ? ORDER BY 1 ASC
Maantic Inc
Can you trace the report and check what are the value getting passed in the SQL query filter params?
Both SQL looks same and it should work. Please try revalidate and save of RD and then check the outcome.
Tata Consultancy Services
Infosys
@Bhumireddy Hi,
With OBJ-Browse ==>I am getting values. no issue with Obj-Browse.
With RD ==> Same issue, resulting no values.
Roshan
Accenture
Hi @roshanalibabas, Can you check whether you are receiving values if you remove the filter condition.
Infosys
@GiridharanVenkat I have checked with no filter condition as well, but no luck. It is not working
Accenture
Is this property recently optimized?
Infosys
@GiridharanVenkat Yes, but after optimization, I have tried to update value for couple of records.
Accenture
Assuming that this and all are old cases, since you optimized now . A new column is created in the table and it doesn't hold any value. you would need to execute recreateindex activity for that. After that you try to run the report , this time it will be bring the data from db.
Updated: 29 Dec 2024 6:28 EST
---> When I try to retrieve a value through a query runner, I am getting results, but when I try to retrieve the same property, it is resulting in no value as output in report Definition.
--> To verify that same property, I have added filters and added a condition with not null. I am receiving records, but the same property, when I added it in the query, is showing no values.
@roshanalibabas He mentioned above that he was able to get the results/values while executing the query in the query runner. That means values available in the DB, Query Runner will bring the values from the DB, not from the BLOB. If aer you using the Stream Function, then only values will come from the BLOB, otherwise it will bring the DB Table.
Ashok
Updated: 22 May 2025 15:39 EDT
Nationwide
Hi Roshan, Have you found any solution for this problem ?
