Capgemini
Last activity: 4 Aug 2023 4:17 EDT
Clear Requestor level data page while switching application from Portal
We have an OperatorID with more than two access groups, each having different access-roles. Both access groups uses the same portal. There is a requestor level Data Page which contains information specific to Operator's access group. On the Portal, when user switches the application, we need to clear this requestor data page, so that it can reload the data based on the newly switched portal's Access Group.
Does Pega provides an OOTB Activity or extension point which can be utilized for this purpose?
Also, We found some PDN content which mentions the use of an OOTB activity "ApplicationFreeClipboard" of class "Data-Portal" to be used for similar purpose. Though, the information in Description and Usage tab is not well defined for this activity. Hence we would like to know if using "ApplicationFreeClipboard" activity fulfills the requirement and is safe to use. Below are the PDN links for reference-
