Hearsay Systems
Last activity: 1 Aug 2023 6:02 EDT
Authentication and API endpoints
Subject: Inquiry Regarding API Endpoint and Authentication for Fetching Data Objects from Pega CRM
Dear Pega Support Team,
I hope this message finds you well. I am currently working on integrating our application with Pega CRM to access and retrieve data objects programmatically. To achieve this, I am in need of information regarding the API endpoint and the authentication method required to fetch all data objects from the Pega CRM system.
Could you kindly provide me with the following details:
1. API Endpoint: Please specify the URL or API endpoint that allows us to retrieve all the data objects (e.g., cases, contacts, leads) from the Pega CRM system.
2. Authentication Method: I would like to know what type of authentication mechanism is employed to access the API endpoint and retrieve data objects securely. Please provide the necessary steps or credentials required for successful authentication.
Your prompt assistance in providing this information would be highly appreciated, as it will enable us to efficiently integrate our application with Pega CRM.
Thank you for your support, and I look forward to hearing from you soon.
Best regards, Shubham Patil Hearsay Systems
