Tech Mahindra
Last activity: 17 Oct 2023 20:49 EDT
Is there a maximum limit on number of records written in a DB table created in PegaData Schema
Do we have a maximum limit or a recommended number of records to be written into a Pega Database Table, probably created in the PegaData Schema?
For example, If we create a sample table in PegaData schema having 8-10 columns and If we use a Obj-Save method with Commit Method considering there are more than 10-15 million records to be written, other than performance and system resource burn out, what are the other issues that can occur. I understand that 10-15 million records is not recommended to be written at once but just in case if it is required what is the best approach.
Thanks and Regards,
Subhajit
