Virtusa
Last activity: 19 Sep 2025 5:53 EDT
PGP Encryption of documents in Pega - Solution
we saw multiple people were looking for solution for implementing PGP encryption in Pega for documents.
Hi All, if you are looking for solution of PGP(Preety Good Privacy) Encryption of documents(PDF, Word, XML, CSV & etc) in Pega. Here is the solution. First of all you need Bouncy Castle Crypto library in Pega. if your already on 8.7 version then all the bouncy castle libraries are available in pega except "org.bouncycastle.util.io.Streams". we cretaed a java project for encryption and decryption using bouncy castle library. and created a jar for that which include this missing steram class as well. we have attached that jar file in attachments, please deploy the attached jar file in to your pega server. then create a library(PGPCryptoLibrary) and java function(EncryptionDecryption) in that library with 5 string parameters. Parametes decription is given below.
Encrypt String inputFileName = "Source File Location on Server with name and extension of file" String outputFileName = "Location where you want to put Encrypted file with name and extension on same server" String encKeyFileName = "Location of Public Key with name and extension of file on server" String passwd = "" -- No password required for Encryption String Mode = "Encrypt"
Decrypt String inputFileName = "Source Encrypted File Location on Server with name and extension of file" String outputFileName = "Path where you want to put decrypted file on same server" -- Only path is required as decryption function will decrypt the file with original file name. String encKeyFileName = "Location of Provate Key with name and extension of file on server" String passwd = "Password" – Password for Decryption String Mode = "Decrypt"
Then check the attached java code file in attachment and paste the code in "EncryptionDecryption" java function that you have already created. - Check the Function Ready to be Compiled Check box - Click on Test Function Compilation - Click on Generate Function - Click on Generate Library Now you can call this function any where and pass parameters according to your requirement.
Reply
Mandeep Rawat Phil Shannon Pavankumar A S -
Many thanks for your detailed post.
Also note that there may be a Marketplace offering which could help users looking for another method of encryption.
See my response in PGP encryption in pega for files
Toyota Financial Services
Hi Vishant,
Hope you are doing well, I have tried to implement the above solution to encrypt and decrypt the file which is already in a location.
Imported the library and created the java function. I have passed the parameters as you suggested above. I am trying to encrypt a file which is in a file location and want to save the encrypted file in the same location with a different file name using the java function. I am getting file not found exception in the logs on new file name which I gave in the parameter as source output.
I have done this exercise using file data sets and it is working as expected. But, I want to try this using your customized solution in a activity.
Can you please help me here or anyone who has implemented this one.
Thanks in Advance.
Dileep
cognizant
@DileepBalaga , I am facing same error.Did you find any solution for this?If so,can you let us know.
I have tried the solution which was mentioned by vishant and it did worked.
In the beginning I faced issues with Jar and Java code.. After multiple retry the code worked.
Please attach the error logs you are facing.
Dileep Kumar Balaga
Virtusa
Hi Jwala,
Please check the logs, you will get the exact error. please share the logs with us as well.
cognizant
@VishantC , @DileepBalaga , I can only see below error.No additional error in logs
Error encrypting/decrypting filejava.io.FileNotFoundException: file:/web:/StaticContent/global/ServiceExport/test.txt
Infosys Ltd
Hi @DileepBalaga, Can you please mention the detailed steps on how to implement this using data sets. Thanks in advance Harshil
Virtusa
@DileepBalaga Most Welcome Dileep :) it was nice to work with you.
Virtusa
I have attached the file.
cognizant
@VishantC ,We couldn't make it work in cloud infrastructure as pega doesn't allow third party classes to access/create files in cloud location.Any idea,If anyone implemented PGP in pega cloud environments.
Updated: 14 Apr 2025 9:09 EDT
Areteans
NZ
@VishantC Hi VishantC, Could you please explain what will be the expected input and output ? what we need to send in input and what will be the output? we have a requirement to do the pgp encryption before sending it to SFTP from cloud repository. Will the solution works for this scenario and will this work for the files which are in repository ?
Updated: 1 Apr 2025 0:57 EDT
Wellsfargo Financial Accptnc
@VishantC I tried importing the zip file provided, but getting error as
- pyArchiveType: The selected archive is invalid or of an unknown type. Please validate archive type or select another file to import.
Kindly help us here.
Updated: 12 May 2025 1:09 EDT
EvonSys
@VishantC Hi Vishant,
Trying this approach in v24.2.1.
Steps followed:
1. Import JAR file
2. Created library without any issues.
3. Create a standalone activity to test the library and set the required parameters.
4. While running getting below error:
Caused by: java.lang.ClassNotFoundException: org.bouncycastle.jce.provider.BouncyCastleProvider at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.findClass(PRBaseLoader.java:324) ~[?:?] at java.lang.ClassLoader.loadClass(ClassLoader.java:592) ~[?:?] at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.loadClass(PRBaseLoader.java:249) ~[?:?] at java.lang.ClassLoader.loadClass(ClassLoader.java:525) ~[?:?]
Error in java step :
org.bouncycastle.openpgp.examples.KeyBasedFileProcessor.encryptFile( outputFileName, inputFileName, encKeyFileName, armor, withIntegrityCheck);
Do we need to import any other JAR's or something needs to be configured is pega instance. Please check and let me know.
Arun Sankar
Virtusa
Hi Arun,
have you created function with code written in Pega Java Code.txt file. and call that function in your activity.
Updated: 12 May 2025 2:41 EDT
EvonSys
Infosys Ltd
@VishantCHi Vishant,
Trying this approach in v24.2.2
Steps followed:
1. Imported JAR file
3. Create function with the provided java code and add the 5 parameters
3. Create a standalone activity to test the function and set the required parameters.
4. While running getting below error: Error - Proprietary information hidden: com.pega.pegarules.pub.PRRuntimeError
Error at Java step - org.bouncycastle.openpgp.examples.KeyBasedFileProcessor.encryptFile(outputFileName, inputFileName, encKeyFileName, armor, withIntegrityCheck); Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.bouncycastle.openpgp.examples.KeyBasedFileProcessor<CR> at com.pegarules.generated.EncryptionDecryption2_010101__6446954152874903890.EncryptionDecryption201_01_01(EncryptionDecryption2_010101__6446954152874903890.java:140) Caused by: java.lang.ExceptionInInitializerError: Exception java.lang.NoSuchFieldError: id_hmacWithSHA512_224 [in thread "https-jsse-nio-9443-exec-6"]<CR> at org.bouncycastle.jcajce.provider.digest.SHA512$Mappings.configure(Unknown Source)<CR> at org.bouncycastle.jce.provider.BouncyCastleProvider.loadServiceClass(Unknown Source)
Steps followed:
Can you provide your inputs in what could be the actual issue Thanks, Harshil Rindani
Virtusa
@Harshil8888Hi Harshil,
Can you try Arun Sarkar's solution as he was also trying to configure in 24 version. i guess he was also facing similar issue. try to Installed bcprov-jdk18on-1.80.jar in Tomcat and check.
TFNSW
Hi, Any luck with the above error. I am also facing same issue with 24.2.2 Version. Any suggesstion would help.
Nationwide Building Society
@VishantC Thank you for the detailed steps. We have implemented and it worked. We have to sign the file additionally using PGP, Have you tried this?
Guhan
TFNSW
@GuhanathanV4521 Hi Guhan, Which version of Pega have you implemented? I tried in 24.2.2 and the product documentation says it does not support additional version of bouncycastle jar cannot be imported. Also was it on pegacloud, if so how did you mention the public/private key path?
I tried to rebuild the same using the latest version of jar and converted the filepath to use file content.
