Tata Consultancy Services
Last activity: 4 Jul 2023 3:57 EDT
Auto Complete control with Property of table type as Field value - is throwing unexpected error.
Steps to reproduce:
1. Create property with table type as field value and source the name of the field value there.
2. In the section, use auto complete control in the field and in the source, either use it as "as defined on property" or "DataPage". And if you are using data page as the source, use the OOTB data page to get the field value results.
3. In the portal, type any single character, dropdown will come. But do not select anything from dropdown.
4. Tab outside the field and see the error the screen as mentioned below.
Error: "The Field Value with key value(s) @baseclass/FieldValueName/s does not exist"
