Hopkins Software Pvt. Ltd.
Posted: May 1, 2023
Last activity: May 11, 2023
Last activity: 11 May 2023 2:56 EDT
How to Create Activity Rings Using Concentric Circles
Hi Everone,
My Requirement is to Create Activity Rings Using Concentric Circles. Check Below Image
How to do this?
***Edited by Moderator Marissa to add Capability tags***
@NAGARJUNA Saidu
Hi Mate,
To Create Activity Rings Using Concentric Circles.
Step 1: Open the section where you want to add the activity rings
Step 2: Add new layout to the section (eg: Dynamic layout)
Step 3: Drag and drop a " Circle" control on to the layout
Step 4: Now in the Circle properties, set the diameter and border width to the desired vales for outermost circles
Step 5: Now add another circle control inside the first one, and adjust the diameter and border width of the second circle to make it smaller than first one. ( You can repeat step 5 to add as many circles you need)
Step 6: Save and Test
Hope this helps...! Happy Learning
