Last activity: 7 Jul 2023 13:07 EDT
Date Formatting Change in 8.6?
We have an internal function that ultimately makes use of com.fasterxml.jackson.datatype:jackson-datatype-jsr310. Everything works as expected in Pega 8.5.5, however in Pega 8.6.5 and Pega 8.6.6, I receive the following error
"Java 8 date/time type `java.time.ZonedDateTime` not supported by default: add Module "com.fasterxml.jackson.datatype:jackson-datatype-jsr310"
Has something internally changed in pega with regards to how date/times are handled? I have noticed this issue both in our in house installations as well as on PegaCloud.
@Jerome@quavo
Using ZonedDateTime API
I was unable to find any obvious changes wrt date/time handling. Please see Understanding the Date, TimeofDay, and DateTime property types
Configuring Java compiler access to information
The issue may be due to the version of Java installed.
If you still need help I suggest that you log a support incident for this, via the MSP.
Please let us know the INC reference if you chose to go down that route.
