Areteans
Last activity: 23 Jan 2023 2:34 EST
Generating REST Connector Fails, Exposing integration using a data type.
I am following the Detailed Instructions for the exercise. After I click to create the REST integration (step 6):
- I get a popup saying
“http://localhost:9080/prweb says
Generation process has been canceled and all created records have been removed”
- I dismiss the popup
- In the generation summary I see details “Canceling rule generation, Error evaluating rules using sample JSON stream
Json Structure :-
Json Structure :-
{ "majorDimension": "ROWS", "range": "Sheet1!A1:D5", "values": [ [ "Item", "Cost", "Stocked", "Ship Date" ], [ "Wheel", "$20.50", "4", "3/1/2016" ], [ "Door", "$15", "2", "3/15/2016" ], [ "Engine", "$100", "1", "3/20/2016" ], [ "Totals", "=SUM(B2:B4)", "=SUM(C2:C4)", "=MAX(D2:D4)" ] ] }
