User soft locked while loading tab
We have a requirement from customer to allow users to navigate in another tabs after create a new interaction case, while lazy load data from Technical Support tab loads.
But once the lazy load from composite section inside Technical Support tab starts, a soft lock starts as well, and users cannot check information from other tabs until lazy load activity finishes.
We are using cyCompositeSettings data transform and CompositeSection<n> sections from CustomerServiceForComms v8.7 application, running on Pega Platform v8.7.3, to create the tabs.
Is there any approach that we can use to allow navigation in other tabs while lazy load is on progress?
Thank in advance,
Fabio Assuncao
